Hiss noise?
By nvrmore100 · Sep 22, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,637 views
Posted Sep 22, 2008 · 21:57 UTC#1
Hey folks,
I just installed my F90BT, and I've noticed a very annoying hissing noise (very noticeable when volume is between 01-03). It occurs mainly after driving directions are sounded, or when moving between screens when the beep sound is created.
It does seem to go away after a while, and it is not very noticeable at higher volume levels as it gets drowned out. However, neither of these are great "solutions". :roll:
Any ideas?
Posted Sep 23, 2008 · 05:09 UTC#2
The fan on the back of the deck?
Posted Sep 23, 2008 · 20:53 UTC#3
No definitely not a fan noise. This is a speaker hiss. I thought I might have a bad ground or something, but all my connections are good, and wired bypass is working flawlessly. :?:
Posted Sep 23, 2008 · 21:12 UTC#4
I had a hissing sound coming from my speakers , so i took my d 3 out and started putting electical tape over anything the was metal near the back of the unit , now i don`t hear any hissing at all. :D
just music 8)
Posted Sep 23, 2008 · 21:34 UTC#5
just music 8)
That was my guess too (bad ground). Just wondered if everyone got the same results I had. Oh well, I'm taking my dash all apart anyhow to hook up my ipod cable that my F90 didn't come with even though it said it should have... (at least I got it free). I will check the grounds on everything again, and tape like a fool! :P
Posted Sep 25, 2008 · 20:26 UTC#6
I just posted a reply to your other post about BT being LOUD. A line level converter will fix you hiss problem too! It did for me :)
Vorian
Posted Oct 31, 2008 · 23:36 UTC#7
I know it's a bit late, but I wanted to let you know that I encountered a similar issue. What it boiled down to was me using the wiring harness for a car that already sends output to a factory amplifier. The amplifier is receiving high-volt input when it should be getting low-volt signal (RCA outs, in effect, or in context of an after-market head unit).
So make some adapters to run your RCA outputs to the harness, and the hissing should go. Sometimes it really isn't grounding, but it's a tricky thing to determine.
