Bluetooth volume LOUD!
By nvrmore100 · Sep 22, 2008in Problems/Troubleshooting💬 20 posts👁️ 4,242 views
Posted Sep 22, 2008 · 22:05 UTC#1
Hey folks,
Another annoyance/issue I've seen with my F90BT bluetooth is volume. I have turned the two volume options down to 1 click above the lowest (otherwise no sound is heard at all), and it still scares the bejeesus out of me when I get a phone call! Caller's voices are also incredible loud!
I have tried adjusting the volume on my phone bluetooth volume (iPhone) as this works great with every BT headset I've used, but has had no effect on F90BT.
Anyone have any ideas on how to reduce the volume for both incoming rings and call volume?
Posted Sep 23, 2008 · 04:38 UTC#2
Adjusting the volume on my phone works fine for me (3G iPhone).
Posted Sep 23, 2008 · 05:34 UTC#3
are all your other button beeps loud as well? the loud beeps and volume would happen if you are running speaker leads directly into a factory amp instead of using a low level rca type of signal. the high output from the speaker lead connection would cause that.
so...what kind of car...year, make, model, and factory upgraded sounsystem??
Posted Sep 23, 2008 · 16:32 UTC#4
I've got this same problem, everything else is at a perfect level, but man when a call comes in that ringer blows me away....
Posted Sep 23, 2008 · 17:51 UTC#5
Hey folks,
How was transferring contacts from your iphone into the 90Bt? Pretty easy? Do the contact names appear on the screen when you have an incoming call? What about multiple numbers for the same contact? Im getting a 90bt installed shortly and want my 1st gen iphone to integrate well with the 90bt.
Posted Sep 23, 2008 · 19:12 UTC#6
iphone transfer went easy but when you have multiple numbers for a contact there is still that bug where the avic doesn't know what to do so it creates an individual contact for each number... resulting in the same name for different numbers and you don't know what is what until you call them.
Posted Sep 23, 2008 · 19:40 UTC#7
Does voice recognition work??? And is it displaying the contact name on received calls as well.....these are problems ive read about in the past and just wanted to see if the issues have been resolved. Thanks!
Posted Sep 23, 2008 · 20:57 UTC#8
I transferred my phone book just fine, no issues there (although it makes me say the last name first when doing voice dailing...) So instead of John Smith, I have to say "Smith John mobile".
Otherwise all the BT functions are working just fine, just VERY loud! :)
Skicrave - Odd question for you. Did you have your BT volume down low on your iPhone BEFORE it connected to the AVIC? Or are you saying you can adjust the BT volume on the iPhone during a call and it affects the overall sound coming from your speakers? Mine doens't work in this way, which I would have assumed it would have. Very frustrating! :(
Posted Sep 23, 2008 · 21:00 UTC#9
Thats a good question. The button beeps were very loud indeed. I was able to turn these down considerably in the setup though. Vehicle info:
2007 Nissan Xterra Offroad with the Rockford stereo option.
When I did the install I just purchased the plug in wiring harness and connected the speakers that way. It does have a factory amp, but only run the factory subwoofer (AFAIK anyhow).
Posted Sep 23, 2008 · 21:17 UTC#10
Interesting.....Ive never heard that you have to say the last name first.....I wonder if there is a fix for that. I know in the iphone you can change the sorting order so it organizes by first name........I wonder if you do that and re-transfer the phone book if it will work correctly. So how do you voice dial someone that has multiple numers? And also.....if you add contacts to your phone, do you always have to re-send the address book or will the AVIC recognize there has been a change and basically "sync" the address book or is it all manual?
Posted Sep 23, 2008 · 21:32 UTC#11
I have actually swapped it in my iPhone to be first name first, and then did a resync, same scenario. If there is only a single number for a contact, no need to say "mobile" if there are multiple you have to specify. Otherwise it will say "I have multiple numbers for Smith John, which one do you want?"
I think I replied to your other thread about get your F90 installed, if you figure out how to get your address book going the other way around let me know!
Oh, you do have to sync it up any time you do a change in your addressbook. If only there was mobileme on this thing!
Posted Sep 23, 2008 · 21:38 UTC#12
So it creates multiple contacts under the same name but then it differentiates between mobile, work, and home on all of those contacts. So for example.....Dan Smith has 3 numbers....home, work, and mobile....it creates 3 separate contacts...Dan Smith Home, Dan Smith work and Dan Smith Mobile???? And to voice dial you just say, Smith Dan mobile and it works?? Thats not that bad....i was afraid you would not be able to voice dial anyone with multiple contacts cause it would get confused. Ill let you know if i find a fix for the reverse thing. Finally......ive heard problems with incoming calls not displaying contact name....any experience with this or has it been working fine???????????????
Posted Sep 24, 2008 · 05:36 UTC#13
sounds like thats the problem.
get an adjustable premium amp interface and that will fix your issue. just adjust it until your button beeps are a tolerable level as well as your phone calls.
ive run into this several times and you do have a factory amp for the door speakers as well.
Posted Sep 24, 2008 · 15:16 UTC#14
Hmm interesting. I'll have to poke around in there when I tear it apart in a few days. Maybe I can figure out a way to avoid the amp all together.
Posted Sep 24, 2008 · 15:19 UTC#15
It actually just creates a single contact, with three numbers attached to them. Same way it displays on the iPhone. If you have a contact with more than 1 number and you do the voice dial as:
"Call Dan Smith"
It responds "I have more than one number for Dan Smith, which do you want?"
You can then say "Call his mobile" (or something similar with the keyword mobile in it)
If you don't want the additional step, you can just say it right off the bat, which is what I do "Call Dan Smith mobile" or "Call Dan Smith work"
I've had no issues with it not displaying contact info when people call. Always seems to work for me anyhow.
Posted Sep 24, 2008 · 15:23 UTC#16
Just to clarify, you mean something like this:
http://www.amazon.com/Scosche-4-Channel ... 966&sr=1-1
Sounds reasonable enough, would explain why it seems so loud out of the front speakers as well.
Posted Sep 24, 2008 · 15:41 UTC#17
yep! that will work. that gives you the ability to tone down the signal so that you can match the output of the factory radio to the factory amp so the beeps and the bluetooth arent so loud.
Posted Sep 24, 2008 · 22:19 UTC#18
All right, so ive got the 90bt up and running.....i am pretty satisfied with it. It does take about 50 sec to become up and running, and about 1:30 before the phone gets connected. Ive also noticed that for the first few minutes the unit is kinda "laggy" until it gets fully booted up, but after about 3 minutes its running great.
One issue ive had, has happened a few times, is when the system is booting up, and after the iphone connects to the avic, it will lose the ipod connection and unplugging it and re-plugging it in does not seem to work....it will keep telling me the ipod connection has failed. The only fix is to completely shut off the power and re-start, kinda annoying since by the time this has happened the power has been on for about 2 minutes and im already on the road! Anyone else experience this problem??
Also, the voice recogonition works about 50% of the time....im guessing its because ive got over 6000 songs in my ipod and sometimes it has a hard time matching up exactly what ive said with the thousand of options in the ipod........but......IS there ANYWAY to change the TSS voice for voice commands. Ive got Jason for the navigation, but i couldnt find anywhere to change the computer voice for when you are attempting to make a call or change artists......that computerized samantha is extremely annoying.
Thanks in advance!
Posted Sep 25, 2008 · 20:23 UTC#19
nvrmore100,
I have the same truck as you except mine is a year older. I had the same LOUD problem as you at first so I added a PAC OEM-2 adapter to convert the speaker level outputs to line level for the amp. That item you have linked there should do the trick too. :)
Vorian
Posted Nov 17, 2009 · 00:52 UTC#20
I'm having the same problem with my car (08 honda civic Si) and it has a factory amp as well. can i use a line output converter to solve the problem? if so, how would that go? speaker leads from factory harness to LOC to the pre amps of the f700??
