Ipod Aux Connection
By avicd3gts · Sep 23, 2008in General💬 5 posts👁️ 849 views
Posted Sep 23, 2008 · 14:05 UTC#1
I seem to have a small problem. I have the 2nd gen ipod touch and I cannot use the direct interface wire(yet until someone make converter so i can charge it). I am currently trying to use a aux cable to listen to music. What I did was connect one end of it to the ipod headphone jack and the other to the port in front of the d3 under the volume control but I get no sound. If I unplug it and plug it into my tc's(different car not the one with d3) factory aux input, then I can hear the music. What am I doing wrong?
Posted Sep 23, 2008 · 14:42 UTC#2
is there an aux input setting you have to change?? how many different AV sourcs does the D3 have, did you try them all?
Posted Sep 23, 2008 · 14:51 UTC#3
I beleive it has 2, I tried swithing them.
Posted Sep 24, 2008 · 12:43 UTC#4
Come on guys, someone here has to know the answer to this. I need music. Please help me out.
Posted Oct 01, 2008 · 18:09 UTC#5
You need to get the AV cable from Pioneer CD-RM10.
The input is actually the AV-2 input and it takes both audio channels and a composite video signal. That is why a regular 3.5mm to 3.5mm stereo adapter will not work. The adapter needs three connections (three black rings) on the 3.5mm plug.
Hope this helps.
Cris
