Need help with 2008 2.5s Altima install
By pokerplayer · Sep 23, 2008in Problems/Troubleshooting💬 2 posts👁️ 553 views
Posted Sep 23, 2008 · 16:09 UTC#1
I need help! I'm going to be installing my Z1 in my Altima and need to know exactly where the Pink wire (illumination is my guess) and the green wire(parking break) need to be connected. I've installed decks before but not a GPS unit like the Z1. I have the wiring harness' needed (Crutchfield). Any and all help is much appreciated.
Posted Sep 23, 2008 · 16:18 UTC#2
You may want to try the 'vehicle specific wiring' forum here at avic411.
BTW, pink is for VSS (Vehicle Speed Sensor), and the light green is parking brake. The light green will go to ground if you plan on using the 2 wire bypass...
Garrettoomey
