Hi Guys,
I'm about to install a AVIC f700BT in a 2008 CRV, I'm unable to source a Wiring Harness here is Aus, so I was hoping someone might be able to help me out with a wiring diagram.
Thanks in advance.
Hi Guys,
Thanks in advance.
Radio 12V orange or lt. green + radio, gray 17 pin plug, pin 17
Radio Ground black - radio, gray 17 pin plug, pin 9
Radio Ignition white + radio, gray 17 pin plug, pin 14
Radio Illumination gray (parking lights), red (dimmer) +,- radio, gray 17 pin plug, pins 10 and 1
Factory Amp Turn-on red + radio, gray 20 pin plug, pin 20
Power Antenna N/A
Left Front Speaker (+/-) lt. green - green +,- radio, gray 17 pin plug, pins 12 and 3 or amplifier
If equipped, the amplifier is under the middle of the dash.
Right Front Speaker (+/-) white - yellow +,- radio, gray 17 pin plug, pins 15 and 7 or amplifier
Left Rear Speaker (+/-) gray - brown +,- radio, gray 17 pin plug, pins 11 and 2 or amplifier
Right Rear Speaker (+/-) blue - orange +,- radio, gray 17 pin plug, pins 16 and 8 or amplifier
Center Channel (+/-) N/A
Subwoofer (+/-) pink - blue +,- amplifier under middle of dash
Aux. Audio Input Left (+/-) white - black (common) +,- radio, gray 20 pin plug, pins 13 and 3
Aux. Audio Input Right (+/-) red - black (common) +,- radio, gray 20 pin plug, pins 14 and 3
RSE Video (+/-) N/A
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts orange + XM Receiver, white 14 pin plug, pin 1
The XM Receiver is in the passenger kick.
Satellite Radio Ground lt. blue - XM Receiver, white 14 pin plug, pin 11
Satellite Radio Ignition purple + XM Receiver, white 14 pin plug, pin 2
Satellite Radio Antenna black RF XM Receiver, black 1 pin plug, pin 1
Satellite Audio Left (+/-) green - black +,- XM Receiver, white 14 pin plug, pins 6 and 14
Satellite Audio Right (+/-) red - white +,- XM Receiver, white 14 pin plug, pins 5 and 13
Hi,
I'm looking for the radio pinout diagram on a Honda CR-V EX-L 2009 (Canadian model, no XM). Can anybody provide me with that info, I would appreciate.
Thanks.
RScottyL,
Do you,by any chance, have a diagram for 2008 CR-V EX-L without Navigation? Thanks you.
