Hi all,
I presently have installed in my ML an AVIC-D2 and it works great. The week I was installing this unit I was confused about the VSS wire of the unit and where to connect it to vehicule because my ML does not have a VSS readily available like some vehicules do. All to say that it turned out that I never did need to connect it, my GPS tracked fine and the screen with speedometer also worked perfectly.
My question is, I am looking into the AVIC-F90BT or the 900. Will this model work for GPS and the little Graphic speedometer, has anyone installed this unit without hooking up the VSS wire, please let me know as this is the only thing holding me back.
Thanking all of you in advance. ![]()
