Metra Kit - won't allow Z2 to open
By wjbarton · Sep 26, 2008in General💬 5 posts👁️ 857 views
Posted Sep 26, 2008 · 15:34 UTC#1
Man - my nice install in our just-purchased 04 Expedition was thwarted when I realized the Z2 can't open because of the kit - it starts to open, gets stuck, and closes back, oddly tilted a little more than where it started. It'll tilt back down if I go to the tilt option.
I've seen a few posts with people having the same problem, but haven't seen what was done to fix it - outside of getting a different kit. I'll try to post an image later today. Ideas?
Posted Sep 26, 2008 · 17:09 UTC#2
where exactly is it getting stuck??
Posted Sep 26, 2008 · 17:43 UTC#3
It starts to open, with the bottom starting to slide out and the top sliding down... the bottom gets about a half inch or less away from the unit, then it pauses, then closes again... hope that makes sense.
Posted Sep 26, 2008 · 17:45 UTC#4
can you see around the cut-out where it's hitting the trim piece?
Posted Sep 27, 2008 · 17:23 UTC#5
It's working now - went to an audio shop and picked up another of the same metra kit - the one I had was apparently a little warped according to the guys there. I still can't see where it's warped, but the new kit definitely works.
So for others having a problem where the installation kit won't let the unit open, try another kit.
