AVIC-D3 SUBWOOFER AND RADIO PROBLEM
By alikhan2004 · Sep 28, 2008in Problems/Troubleshooting💬 4 posts👁️ 878 views
Posted Sep 28, 2008 · 09:38 UTC#1
Hi I just installed a AVIC-D3 in my car with 2 12inch Kicker L7's with a Hifonics Brutus amp 1600 watts, but for some reason my radio reception gets really scratchy when my amp turns on also I always hear some static noises and pulse noises come from my subwoofers even tough my unit is turned off. Also when I do have some source turned on my unit my system does not hit properly so what could be the problem?
Posted Sep 29, 2008 · 02:40 UTC#2
HELP ME PLEASE!!!!!!!!!!!!
Posted Oct 05, 2008 · 00:02 UTC#3
HELP!!!!!
Posted Oct 05, 2008 · 05:18 UTC#4
alikhan2004, youre probably not got much response because its probably extremely unlikely that your problem has anything to do with your D3. The D3 is just putting out a line level signal to the amp and whatever happens to that signal after is controlled by your amp. The problem is probably something to do with your amp or maybe the way you have it hooked up. If its interfering with your fm radio reception Id bet its something from the amp feeding back into the D3. Maybe theres a bad ground somewhere maybe even inside youre amp. If you have another amp (any amp) Id try hooking it up and see if you still have the same problem. That would be a good place to start to try to troubleshoot.
