You can customize a picture for the phone book record. Some pictures are already stored in the hard disk drive, and you can also import JPEG format pictures, such as a picture from your digital camera, by using a CD-R(-RW). You can use pictures by burning them onto a CD-R (-RW) with your PC and insert that into the navigation system.
Limitations for importing pictures
❒ You cannot use a CD-R (-RW) containing MP3 files or Audio data (CD-DA part) for importing pictures.
❒ When storing pictures on a CD-R (-RW), create a folder named “Pictures†in the CD-R (-RW), and store the picture files in this folder. (Up to 200 picture files can be used in total, including pictures that are already stored in the hard disk drive and pictures in the CD-R (-RW).)
❒ When you burn a CD-R (-RW), limit the number of folder hierarchy levels to eight.
❒ You can only use a CD-R (-RW) finalized with single-session for importing pictures.
❒ You can only use a CD-R (-RW) finalized with “Mode1†for importing pictures.
❒ Only JPEG format (“.jpg†or “.JPGâ€) pictures can be used. Progressive format JPEG pictures cannot be used.
❒ Using only the standard Latin characters (alphabets of both cases: A-Z, a-z) and numbers (0-9) is recommended for the file name. If you want to use letters with diacritical marks (such as ä or è) for file name, finalize the CDR(-RW) with Joliet (Unicode) format.
❒ Pictures up to a maximum of 2592 x 1944 pixels can be used. We cannot guarantee proper operation for a picture bigger than this size.
❒ After changing a set image that was imported from a CD-R (RW), you must use the CD-R (RW) where the image is recorded to restore the previous Splash Screen.
