bypass without connector 2
By avicer · Sep 29, 2008in Hacks/Mods💬 8 posts👁️ 1,874 views
Posted Sep 29, 2008 · 02:12 UTC#1
Hi,
I did the bypass on the parking brake wire successfully. I do not have a connector two, hence cannot just plug a cable into the harness to bypass.
Does anyone have an idea how to bypass without this plug? I was thinking of wiring a cable to ground and to that last pin, but I am not sure how I would secure it...
Thanks in advance!
Posted Sep 29, 2008 · 03:07 UTC#2
You can contact pioneer for a replacement harness. Using a harness is the only recommended wiring technique to avoid the possibility of fire or damage to the unit.
Posted Oct 15, 2008 · 07:14 UTC#3
I soldered the mute wire directly to the required pin (the bottomost pin on the rightside) and it works fine
Posted Oct 17, 2008 · 16:24 UTC#4
If you go this route, I'd add a small piece of some heat shrink to it as well...just to be safe.. :?
Posted Oct 17, 2008 · 21:27 UTC#5
X2 ^
Posted Oct 18, 2008 · 08:14 UTC#6
I couldnt find any shrinkwrap, so i covered the soldered pin and exposed part of the wire with electrical tape. I also taped down the wire to the headunit body to minimize vibrations shaking loose the solder. I think it should be sufficent :D
