How do you use the equalizer in N4?
By bird333 · Sep 30, 2008in General💬 9 posts👁️ 1,367 views
Posted Sep 30, 2008 · 18:07 UTC#1
I have read the brief explanation in the manual (not much help). The problem is everytime I change one band and switch to another; the previous band moves to something else. Is it not possible to change each band individually? Also what is 'Q' level for?
Posted Oct 02, 2008 · 15:21 UTC#2
Anybody????
Posted Oct 04, 2008 · 04:03 UTC#3
The equalizer in your AVIC is a parametric equalizer, which means that you can not only control the amplitude(volume) of each selected band, but the center frequency, as well. The "Q" refers to the affected bandwidth of your controllable equalization band.
Physically speaking, Q is 2π times the ratio of the total energy stored divided by the energy lost in a single cycle or equivalently the ratio of the stored energy to the energy dissipated per one radian of the oscillation.
Equivalently (for large values of Q), the Q factor is approximately the number of oscillations required for a freely oscillating system's energy to fall off to 1 / e2π, or about 1/535, of its original energy.
When the system is driven by a sinusoidal drive, its resonant behavior depends strongly on Q. Resonant systems respond to frequencies close to their natural frequency much more strongly than they respond to other frequencies. A system with a high Q resonates with a greater amplitude (at the resonant frequency) than one with a low Q factor, and its response falls off more rapidly as the frequency moves away from resonance.
Would you like to know more?
Posted Oct 22, 2008 · 18:24 UTC#4
Thanks for the responce. Yes, I would like to know more (in English, I'm a dummy when it comes to this ;)). This is weird because Pioneer says this shouldn't be happening.
Posted Nov 06, 2008 · 04:25 UTC#5
Wait, lemme get this straight. Once you set up a band on your EQ(freq, Q, and amplitude), and move to the next band for adjustment, the previous settings change on their own?
Posted Nov 12, 2008 · 01:41 UTC#6
Yes. It is just nuts to me. I have done the video bypass if that makes any difference. I am gonna try to check the forum more often, sorry.
Posted Nov 12, 2008 · 05:25 UTC#7
Sounds like you need an exorcist, not a technician... :twisted:
Has this unit ever been exposed to anything detrimental, i.e.: water. lightning, severe impacts, nuclear testing?
Posted Nov 13, 2008 · 00:57 UTC#8
It was brand new in the box.
Posted Nov 15, 2008 · 05:04 UTC#9
Ummm, get it replaced.
