2006 Hyundai Sonata, 4 cyl 2.4 & Auto trans - Speed Sign
By dtwins · Sep 30, 2008in Vehicle Specific Wiring💬 5 posts👁️ 1,114 views
Posted Sep 30, 2008 · 21:34 UTC#1
I'm not sure where to connect the speed signal wire from my AVIC f90BT. Is it true this is a "VSS" wire near the gas pedal under the dash? What color is the correct speed signal wire? Is the reverse wire near this area also?
The car is a 2006 Hyundai Sonata
2.4L 4 Cylinder Engine
Automatic Transmission
Posted Oct 03, 2008 · 10:38 UTC#2
Reverse Light blue + driver kick, harness to rear
Speed Sense yellow data link connector, pin 6
The data link connector is under the driver side dash.
Posted Oct 03, 2008 · 14:38 UTC#3
Thanks MisFit.
Is the data link the harness connected to the gas peddal?
Posted Oct 03, 2008 · 16:34 UTC#4
no, its at the bottom of the dash panel
Posted Oct 03, 2008 · 17:06 UTC#5
Thanks. I will look for it and connect it that way. It was connected to a pink wire just above the gas pedal where there is a simple harness.
