A great resource for that type of information can be found at
www.the12volt.com
In fact, look here specifically (2001):
http://www.the12volt.com/installbay/for ... p?TID=8883
Looks like it is half way down this list...
I would connect the VSS for dead reckoning (I think the Z1 has that). Good luck!
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|purple |+ |ignition harness |
| IGNITION|pink/red |+ |ignition harness |
| SECOND IGNITION|pink/yellow |+ |ignition harness |
| THIRD IGNITION|black/green |+ |ignition harness |
| POWER LOCK|black |- |driver door module or *1 |
| POWER UNLOCK|blue |- |driver door module or *1 |
| PARKING LIGHTS +|gry/red & gry/blk *5| |illumin. control module *5 |
| HEADLIGHTS|yellow & yel/blk |5wi|illumin. control module *5 |
| DOOR TRIGGER|*2 |- |pin switches or *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|brown/yellow |- |trunk light or *1 |
| HOOD PIN|brown/red |- |hood switch or *1 |
|TRNK/HTCH RELEASE|yellow |- |release switch or *1 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| TACHOMETER|*4 | |ignition coils |
| SPEED SENSE|green/black | |radio |
| BRAKE WIRE|black or blk/wht |+ |brake pedal switch |
| HORN TRIGGER| | | |
| WIPERS|yel/wht & yel/gry |+ |wiper motor |
| LF WINDOW UP/DN|*3 | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE|*3 | | |
