How do I get my ipod touch to play videos.......
By dqlostsoulz · Oct 03, 2008in iPod/iPhone/iPad💬 13 posts👁️ 2,915 views
Posted Oct 03, 2008 · 08:09 UTC#1
.......on my z3??? I have the cd-ib100II and it plays the music fine,but does not play videos. Is there something im missing..........any suggestion.
Posted Oct 03, 2008 · 08:32 UTC#2
Your ipod adaptor doesn't transfer video. You can buy the Apple cable that outputs to RCAs and plug it into the A/V input though
Posted Oct 03, 2008 · 08:43 UTC#3
Where do i get and how do i install it??
Posted Oct 03, 2008 · 20:22 UTC#4
The apple store. You pull out your deck, plug in the RCAs (red, white, and yellow) into the A/V input, put the deck back, turn on the A/V input in the Z menu
Posted Oct 03, 2008 · 20:38 UTC#5
Do you know where I can get them it cheap?? :?:
Posted Oct 03, 2008 · 21:43 UTC#6
You can use a standard Camcorder AV cable to connect your video iPod to a the Z once you understand the signal flow that Apple have adopted in favour of current standards. This will save you cash and you can always spray the cheaper black cable white if you insist on the white bling thing!
Apple iPod sends it's video signal over the red RCA cable. Normally it would be the yellow one. Hence people get confused, give up thinking they need a 'special' cable and shell out $60 at the apple store.
Here's the configuration.
Red RCA plugs into Z's yellow RCA jack.
Yellow RCA plugs into Z's white RCA jack.
White RCA plugs into Z's red RCA jack.
You may even have one of these laying around the house...
Posted Oct 03, 2008 · 21:52 UTC#7
Thats it how come they do not plug color to color?.............where do you plug the other end too on the itouch?? Is it where the headphones go?? How is the quality and sound??
Thank you very much.
Posted Oct 03, 2008 · 22:05 UTC#8
They do not plug color to color because apple wants you to buy "their" cable. Quality is the same using either cable. Yes, plug in where the headphones go.
Configure the ipod settings for TV out:
To open these settings, choose Videos -> Video Settings from your main iPod menu. This screen offers three settings: TV Out, TV Signal and Widescreen. Adjust to produce the video playback style you need.
TV Out
Whenever you play a video file, your iPod must make a choice. Video iPods either play video on the built-in screen or they transmit a video signal out of the microphone jack. They don't do both. The TV Out option controls which behavior occurs.
Use this setting to choose from:
No. Playback remains on the iPod itself.
Yes. A TV signal is produced.
Ask. The iPod prompts you whenever you play a video file.
I always use the Ask option. Yes, it does add an extra step whenever I play a video file, but it gives me the flexibility to choose playback behavior on a case-by-case basis. I like that.
Posted Oct 04, 2008 · 05:04 UTC#9
Thank you very much i will try this 2marrow..................your a gentlemen and a scholar 8)
Posted Oct 04, 2008 · 07:33 UTC#10
I believe TV OUT on the iphone/ipod touch is output through the dock connector only, not the headphone jack but I could be mistaken.
Posted Oct 04, 2008 · 07:38 UTC#11
oh boy can anyone verify that ??
Posted Oct 04, 2008 · 08:59 UTC#12
I use the dock connector on mine and it works. Thats why I told you to but the Apple cable
Posted Oct 04, 2008 · 15:21 UTC#13
The dock connector will work as will the standard headphone jack. I have not used that since my first video iPod but it does work
