Installation help
By Don Nguyen · Oct 03, 2008in Problems/Troubleshooting💬 3 posts👁️ 964 views
Posted Oct 03, 2008 · 17:26 UTC#1
I know this is probably a simple question/problem, but I can't seem to figure it out.
I have a set of front speakers, tweeters and mids. When connecting the speaker wires to the AVIC N3 unit, I noticed that in the installation guide it only specified front speakers, and not seperate for the mids/tweeters.
Is that correct, or did I wire them wrong?
thanks.
-Don
Posted Oct 03, 2008 · 18:05 UTC#2
Typically the mid and tweeter is connected to some type of cross-over/hi-pass. The N front speaker connectors would go to the cross-over.
Posted Oct 08, 2008 · 20:52 UTC#3
garrettoomey is right but in the case you bought them as sepperate componets then you would run the tweeters in parallel with the mids but you might want to add a cap on there
