Poor reception with FM/AM Radio
By westy4990 · Oct 03, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,287 views
Posted Oct 03, 2008 · 23:01 UTC#1
Alright, so here is my problem, my reception is really bad with my F700. Radio stations that were normally crystal clear are now cluttered with lots of static at best. My car is a 2007 Subaru Impreza which has an internal powered antenna (I believe). Anyhow, I did check to see that the antenna was plugged in on the back of the deck. Am I missing something else simple? Thanks in advance for the help.
Posted Oct 05, 2008 · 18:55 UTC#3
I've F900BT (in NL) . FM reception with TMC is OK, AM is poor, LW is nill-to-zero.
LW only give me one loong sizzling-beep. I nor the dealer can figure things out. Dealer is BTW not oriented on car-systems.
My other system (Fabric Ford "Kenwood" Navigation) did OK receiving 162KHz
Posted Oct 05, 2008 · 19:20 UTC#4
Check to see if your model of car has an antenna amplifier
Posted Nov 11, 2008 · 20:45 UTC#5
Hi,
Some feedback & cause about poor reception.
My Chevrolet is packed with voltage-converters which transmits interference in the 150Khz en 192Khz band. This the reason why I don't have any reception. Apparently the "new" (SW/PS) technology rules out the old radio reception. It's a real pity . . .
Anyway, just to let you know. . . .
