f-900bt blackbarry
By audiosport · Oct 06, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,723 views
Posted Oct 06, 2008 · 19:55 UTC#1
my bt dont work w/blackbarry
any one?
i call pioneer they say...
we are working onit...
Posted Oct 08, 2008 · 17:20 UTC#2
F900Bt and BB8820 works fine with BT including phonebook sync
Posted Oct 08, 2008 · 18:45 UTC#3
my blackberry 8703e works just fine with my 900
Posted Oct 08, 2008 · 18:49 UTC#4
My BB Pearl 8100 works just fine - takes forever for it to connect - @ 5 minutes - but once connected works like a champ
Posted Oct 09, 2008 · 00:15 UTC#5
I have an 8100 and I had to update the phone to get it to work. Now it works fine. Your service provider will have all the update imformation.
Posted Oct 14, 2008 · 01:39 UTC#6
I have a 8310 from AT&T and it works like a champ (runnin OS 4.5, not sure if that makes a difference)
Posted Oct 14, 2008 · 18:19 UTC#7
I have a Blackberry 8830 (World Edition - Telus). didn't have issues at first, .. but now it connects and disconnects after less than a min.
I tried deleting it and pairing again, .. and disable encryption, .. but no luck,
I believe I have the latest FW on my BB, .. I will check that.
And I know I have the latest software/fw for the pioneer.
Kaveh
Posted Oct 14, 2008 · 20:37 UTC#8
k_afshari - go to crackberry.com, they will have instructions on how to update your phone, not all carriers have officaly released the update yet, but there are ways around that, I was running the old software on my BB with a N3 and I would drop the phone along with ask me for the pairing code every time i got into my car, with OS 4.5 it has asked me for the code twice and never drops the connection. Good luck!
Posted Oct 15, 2008 · 18:49 UTC#9
will it not find it at all? or is it constantly disconnectiing? i found with my 8330 that once i paired initially, i had to connect via the phone and it would stay connected...
Posted Nov 05, 2008 · 17:52 UTC#10
With Firmware 2.0, I was able to connect to BlackBerry 8830 world Edition (Telus, Canada). With older Firmware, the Bluetooth kept disconnecting every ~15 secs. Now the phone is generally ok. It does lock up once is while, . but usually recovers. Call waiting (switching lines) is very buggy. Also if you make the call from the phone, the Pioneer doesn't handle it very well. (lock ups) And when are you in a call, you can not switch between screens.
But overall, it is better than not having a phone functionality at all (older firmware).
Cheers
Kaveh
