I've buy a used D1, and the previous owner used the Power Antenna Wire to hack the system, and didn't put it back on.
So now I have to figure how should I plug a new blue wire, and where I have to put it in the plug. And however where should I plug the "fake" wire needed to be grounded for the hack.
I know it have to be grounded, but all picture I have seem came from D3 and the wire is on RCA plug, but, my RCA plug didn't seems to be the same as the D3.
Empty slot that I've by now are :
power plug: Top left corner (left of yellow cable) and both side of purple/white wire
RCA plug: Upper and lower between rear monitor output and Rear View camera.
If you know the name of the wire plug to be insert into the plug casing, it will be great to purchase it with the name of, and not only a description.
Thanks for your help.
