Pointer on D2 doesn't stop moving when vehicle is stopped.
By Candyman80191 · Sep 09, 2006in Problems/Troubleshooting💬 7 posts👁️ 1,396 views
Posted Sep 09, 2006 · 16:18 UTC#1
I am having an issue with my D2 in a 2002 Honda CR-V. When I am stopped at a traffic light the D2 seems to think that I am still moving....probably due to the VSS wire (connected to the tach). Eventually the GPS in the D2 corrects the position, but that could be blocks away. Is there any way to correct this issue?
Posted Sep 09, 2006 · 16:28 UTC#2
:lol: Why is the VSS wire hooked up to the tach? Then it thinks you're moving as long as the engine is running!
The solution is to connect the VSS wire to the car's VSS. At the very least, it would be better to have the VSS wire connected to nothing at all than the tach.
Posted Sep 09, 2006 · 16:32 UTC#3
Go to main menu, Settings , then Hardware Info , Connection Status. Speed Pulse should read zero when you are stopped. If not I would think that maybe VSS is hooked to the wrong wire.
Posted Sep 09, 2006 · 16:36 UTC#4
Well, that makes sense. I actually had a guy from Honda tell me which wire to connect the VSS to. Any idea which wire I need to use for a 2002 Honda CR-V?
Posted Sep 09, 2006 · 18:30 UTC#6
It's in the cruise control module harness to the left of the steering column, blue with a white stripe.
Posted Sep 09, 2006 · 21:20 UTC#7
Perfect. That does it. Thanks guys.
