Shut off Navi?
By g0tw33d · Oct 07, 2008in General💬 11 posts👁️ 1,698 views
Posted Oct 07, 2008 · 20:44 UTC#1
Is there anyway to not automatically turn the system on upon starting the car or turn it off as a whole?
Posted Oct 07, 2008 · 22:15 UTC#2
As long as the car is turned on, the unit will be powered on. The only way around that would to be putting a toggle switch on the radio's red (ACC) power wire.
Posted Oct 08, 2008 · 05:39 UTC#3
that's annoying... I'd never thought about it but sometimes I like peace and quiet in my truck! Is this a common "feature" of nav systems... no power off button?
Posted Oct 08, 2008 · 05:49 UTC#4
Just press the source button on the top left hand corner and source it to off. It will stay that way until you switch it on. You will however still get turn-by-turn guidance even when sourced OFF
Posted Oct 08, 2008 · 07:29 UTC#5
Not if there is no route programmed.
If you don't want the unit making noise:
1 - got to the source screen and hit the off button which will turn off the A/V portion of the unit.
2 - Delete any currently selected routes.
The bluetooth function will still work this way if you get or need to make a call.
Posted Oct 08, 2008 · 17:46 UTC#6
Pretty sure people know it doesn't announce turns without a route plotted :wink:
Posted Oct 08, 2008 · 19:11 UTC#7
You are giving people way too much credit. The human race in general, especially these days, are a pretty dimwitted bunch.
Posted Oct 09, 2008 · 15:12 UTC#8
you can do it on the kenwood dnx5120 but if you need that much peace and quiet your truck might not be the spot :wink:
Posted Oct 10, 2008 · 08:02 UTC#9
At off, will the screen still be on? The light can be disturbing at night... at times... lol
Posted Oct 10, 2008 · 16:45 UTC#10
Yes, but you can turn the screen completely off too. Its in the settings menu...under system if I remember correctly
Posted Oct 10, 2008 · 16:49 UTC#11
so your options to turn the unit off are:
without a toggle switch: Turn off any AV source on.
Delete any current route programmed
press screen off in system settings
-or-
with a toggle switch: flick a switch.
