Sat Radio Volume
By DiscoLad · Oct 08, 2008in General💬 6 posts👁️ 1,062 views
Posted Oct 08, 2008 · 00:08 UTC#1
Nav system is installed and works great. There is one oddity though - my XM is coming in quite quietly, while my Sirius is much louder. Unfortunately I can't compensate for this with the volume controls (that I can see) as both the XM and Sirius are control together (you can't set the volume independently).
Has anyone else experienced this? Any suggestions?
I keep having it turned up to listen to XM then get deafened when Sirius or any other source comes on.
Posted Oct 08, 2008 · 02:06 UTC#2
Turn SLA all the way up when your source is selected to XM.
Posted Oct 08, 2008 · 02:21 UTC#3
What is the SLA? the source level? If so, this ups it for both XM & Sirius at the same time, so Sirius will always be much louder.
Posted Oct 08, 2008 · 04:24 UTC#4
SLA (source level adjustment)
Guess I never tried both Sirius and XM, but you would think they would be different since they are different sources.
A Pioneer rep once told me they screwed up on the XM tuners output level, and too adjust the SLA all the way up every time.
I guess you could get a little crazy, figure out the output wires on the tuner's circuit board and add a audio line driver.
Posted Oct 08, 2008 · 05:46 UTC#5
They both go up with SLA, you just have to use the volume each time you switch between the two
Posted Oct 08, 2008 · 15:31 UTC#6
Thanks guys. I assume the same goes for the phone, as it is quite quiet despite being turned up all the way.
