I'm putting a Pioneer AVIC D2 in my C6 Corvette…I'm a newbi here and any help would be appreciated.
Does the D2 require I find the VSS (Vehicle Speed Sensor) wire to connect to? Some cars have it in the wiring harness already, some don't. If so, where is the VSS wire in the C6?
Does the AVIC D2 require reverse signal wire hookup too? If so, where would I find that?
I know that I will need THIS mounting kit.
I know that I will need THIS to have XM.
I was told that I could use my stock XM antenna for the aftermarket XM receiver. I imagine I would have to cut the stock harness though. Does anyone know?
I believe I will need THIS to retain the chimes and OnStar, but I'm not sure yet.
Aside from an antenna adapter, will I need any other wiring harnesses? Am I leaving anything out? :?:
I realize these are rapid-fire questions but I thank you for your help. :D
Posted Sep 09, 2006 · 17:44 UTC#1
