grounding the wires for bypass
By anon · Oct 08, 2008in Hacks/Mods💬 2 posts👁️ 1,529 views
Posted Oct 08, 2008 · 20:43 UTC#1
Stupid noob question: does 'grounding the parking and mute wires' mean that you solder (or use a wire tap) a ground wire somewhere along the parking brake wire and mute wire? Do you use a third wire to make the connection between the existing ground and the brake/mute wire?
Posted Oct 08, 2008 · 21:04 UTC#2
There are a thousand ways to do it, but you want to end up with the 'mute' and 'parking brake' wires connected to the black 'ground' wire for the AVIC, or connected to the same location in the vehicle as the black 'ground' wire.
Personally, I tie all 3 (mute, PB, Black) and then connect it to the vehicle ground.
