Turning off navi voice guidance
By SpdDmn · Oct 09, 2008in Hacks/Mods💬 2 posts👁️ 1,079 views
Posted Oct 09, 2008 · 03:14 UTC#1
Just got my F90bt installed a couple weekends ago, and i love it!! Couple of kinks to work out, which I'm sure there are hacks for that I have yet to discover...
One thing I'd like to do ASAP is remove the voice navigation. It's so annoying to have my music muted at 800 meters to a turn, 500m, 300m, etc etc!
Has anyone come up with a hack for this that I've missed in my quick look through and searches?? I'd like to either reduce the number of times the system warns me of an upcoming turn, or failing that, turn off the warnings completely (but obviously NOT get the mute in my music).
(I apologize in advance if this has been beaten to death, i'm new to the site :))
Posted Oct 09, 2008 · 16:29 UTC#2
You could try using att instead of mute for the route guidance, it helps a little bit. Turn your AV source to off then settings>av settings>should be the box in the lower left that says ATT/Mute. Select that button. If its greyed out that means you didnt switch your av source to off.
