Ok guys after a lot of research I found the VSS wire on my Cadillac CTS 04 and tapped into it. I had to remove the speedometer cluster....
Well I can't find what wire I can tap in the Illumination wire too.......
I even got a multimeter and found wire with current while headlights were on and when I found one I switched off the headlights to see if the current went away but was unsuccessful in finding a wire to tap in the illuminationwire.... any ideas?
Also any idea on the reverse wire?
