Anyone know if i can get some kind of tv tuner antenna for my D3??? if yeah where can i buy it??
T.V. Tuner for D3
dont bother wont work in a few months
why not???
all tv is converting over to digital in feb 2009 and you will not have a digital tuner out in the market yet
why not???
There are several digital tuners that are small enough to be installed into a car and that have external power supplies (so they can be used with a cigarette lighter power adapter instead), so from that aspect, the answer to your question is yes, there are. For example, one I might look at would be the DTV Pal from Dish Network [a.k.a. Echostar].
However: attempting to actually USE a digital TV tuner in a car is, frankly, rather pointless. You will only be able to use it while stationary, because the Doppler effect totally destroys a digital signal while moving. And once stationary, you'd likely have to reposition an antenna to get the best signal, which would likely get old, fast.
Also, any digital tuner would not be able to be controlled from the D3... which sucks as well.
Basically, don't waste your money on a TV tuner right now because you would only be able to use it for 3 months, after which it would be a useless brick.
And as far as digital TV tuners, you might have to wait a while, maybe even a year or more, before those start being developed/manufactured for mobile use.
Direct TV has a portable satellite that would allow you to view it via RCA's. Works well but can have choppy picture quality at interstate speeds. Downside is that it is freakin expensive
Also, it's really big and really ugly.
http://www.mobilsat.com/Mobile-satellite-TV/Raysat-Speedray-1000.htm
http://www.trendhunter.com/trends/tracvision-directv-for-your-car
They have a portable one it is slightly larger then a large breifcase and has the tuner and everything built in, including a 17" screen. A buddy of mine has it in his RV and when they go camping. I have only seen it when it was parked in his driveway but it had a clear signal and good picture quality.
Here's a tiny DTV tuner, for the cost of tax plus 1-cent after gov't coupon.
It uses an external power supply so it should be easy to set up for mobile use.
It probably won't work while you're driving, but should be fine for watching TV while sitting in a parking lot on your lunch break or if you just dropped the wife off to do Christmas shopping and would rather sit in the car and wait.
I doubt you would be able to control it via the HU and then you would also need an antenna to receive the signal
No, you definitely can't control it from the HU and any Over-The-Air tuner will need an antenna.
There is no DTV solution that can be controlled by the HU yet. I imagine if one existed, Pioneer would charge $350 for it considering the ridiculous price of their previous analog tuners.
I've just ordered an HTC Touch Pro from Sprint that has video out on it. I have my Slingbox set up so I can watch TV from my phone. Should be able to output from the phone to the D3.
Will see if it works, I know Sprint TV video is blocked from the video output but not sure about Slingbox.
How's that? HD Radio is digital and it works while moving. So is XM and Sirius. Mobile phones work.
I think the theory of it would work. The frequency should be high enough that the Doppler effect at such slow driving rates should be insignificant.
