Hello guys I just recently had my avic d3 installed at Best buy. I'm going back on Friday because the bluetooth doesn't work. The wiring seems to be right according to the guy and the unit does make the call but I cant here anything when the call has been made. Any suggestions as to what is wrong?
Also, I was researching here about powering the unit w/o ignition. With my old stock symphony radio, when the key is in the off position the radio still works. But with this unit the radio only works when the key is in the on position or when you start the car. My car does not have an accerssory position. It has the off position, on position and start position. When I had my stock radio before the radio still works. The guy said he wired it like that because if he wired the red wire on the constant position then the system will be on every time and it will drain my battery. He said the avic d3 even when its off the screen is still on. If the red wire was wired on the constant position would the unit still be on even if the key wasnt on the ignition? I want the unit to act like the symphony. When its the key is in the off position I can still listen to my radio. With this unit I have to turn the car on or start the car to listen to my radio. It bothers me because at night if I want to listen to the radio without starting my car I cant. And If I turn on the car my drl lights will always on.
