Where is the best place to ground the d 3 in a 2004 yukon so i wont get any winning noise, should the ground be near the d3 or away from it?
Posted Oct 15, 2008 · 21:01 UTC#1
Your gonna wanna post that in the D-Series forums...
http://avic411.com/forum/viewforum.php?f=6
whiining noises are usually because of different lenght power/ground cables, or your head unit rca cables are next to an unsheilded transmitter/unsheilded power cable. Good luck
You should be just fine with the ground from your factory wiring harness. If your running amp to your speakers, it might be the amp's ground that is putting out that whining sound or your speaker wires are to close to power wires running in your car. If your not running a speaker amp, then just get a factory harness adapter and use the ground from there.
