2001 tundra vss location
By tundra1012 · Oct 15, 2008in Vehicle Specific Wiring💬 9 posts👁️ 3,033 views
Posted Oct 15, 2008 · 23:34 UTC#1
so any one know where the vss is and is there a possability that i can uatlise the factory amp
Posted Oct 15, 2008 · 23:47 UTC#2
I can't find anything on the 2001, however on the 2000 it's listed as VSS Wire Green/Orange Pin 15 at BCM. They might be the same so you could try that. I'd test it first prior to hooking up to it to make sure.
Posted Oct 15, 2008 · 23:57 UTC#3
yea im not sure but i called my buddie over at toyota and hes going to printup a wiring digram for me because i havce searched everywhere and cant find shit about it
Posted Oct 16, 2008 · 05:14 UTC#4
For the 2002 and 2003 I found:
green/orange at the instrument cluster in the brn plug.
Posted Oct 16, 2008 · 23:13 UTC#5
is it preety easy to get out the interment cluster and where is it opn there ?
Posted Oct 17, 2008 · 00:26 UTC#6
I'm not sure how easy it is to get the cluster out. I just posted the wiring info that I found online. Sorry.
Posted Oct 17, 2008 · 02:12 UTC#7
I too don't know and was posting info I found on line also. Tapping into the wire off the BCM module might be easier to access than pulling the cluster. What I'd suggest is you buy a manual such as a Chiltons or Hayes for your vehicle. This should give you info on the location of your BCM and/or pulling the cluster, which ever route you choose to go. If you're still unsure you might be better off taking to a car stereo install shop and having them do it for you. That way you'll know it's hooked up correctly, and I wouldn't think would cost very much.
Posted Oct 18, 2008 · 18:00 UTC#8
i went to some of the shops around here and to put in the avic n1 it was going to be around 3 hunfred dollars to put it in so not cheap thats forsure but that you for the advise just think im going to take it to my budy that works at toyota and have him look for it for me but thanks anyway
Posted Dec 22, 2009 · 05:09 UTC#9
HEY FOUND IT!
YELLOW/red stripe
the computer located behind the glove compartment
from Left to right 3RD main connector (i think is the center one) it has less wires than the others
YELLOW with a RED Stripe
It comes right from the sensor it self
