This is probably a noob question, but I was wondering if anyone knows if the GPS Antenna for the Avic-F700BT will fit the D3?
Thanks for your help
Yes. Same gps antenna.
actually, same gps antenna, but different plug. when i replaced my d3 for my f90bt, the plugs didnt match up. so i had to change out the antenna.
You can just pull the plastic plug off and it will work too if its too much work to pull the whole antenna out
