Emergency Brake Warning Screen
By berto210 · Oct 17, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,246 views
Posted Oct 17, 2008 · 13:15 UTC#1
I noticed in the last few days that the emergency brake warning screen would just pop up during driving. I finally narrowed down that, when I proceeded to drive over 80 mph the brake warning will appear and disable the navi. I made my changes to the ini file prior to all this and set the speed to 128. it works fine up to 80 mph. Has any one experienced this? It is constant, so anytime i go over 80 for the first time. Thanks
Posted Oct 17, 2008 · 13:56 UTC#2
I've personally never had this problem, and all I've done is ground the Parking brake wire.
Posted Oct 17, 2008 · 14:45 UTC#3
80 M/h * 1.6 = 128 KM/h. If you do тщне want to do the software bypass, up the value to, say, 256 and you'll be good to 160 M/h...
Posted Oct 19, 2008 · 01:49 UTC#4
Thanks much. That worked perfectly.
Posted Oct 19, 2008 · 06:39 UTC#5
You're welcome :)
Posted Oct 19, 2008 · 17:49 UTC#6
Also you could just drive within the speed limits :wink:
