I installed the unit today.
When calling people from contacts, everything works fine. But when receiving calls, some contacts names doesn't apper, just the number. Why is that? It's a European version, all the contacts are saved in the same way..
try to write phone numbers without space between land code (+xx) and number . ( +xx xxxxxxxx ---> +xxxxxxxxxx)
may help ![]()
they are all without the land code...and so far all but one worked fine when incoming call..outgoing call always shows name.
Someone posted on here some time ago that depending on the carrier that the incoming call is coming from, it would change how the number coming in was displayed which in turn would change how the unit matches it up. Just an idea as to why it may be happening? So far since editing my phonebook all of mine come in matched up... *knock on wood*
