testmod..can somebody help me plz..
By techno21pro1 · Oct 21, 2008in Hacks/Mods💬 8 posts👁️ 1,939 views
Posted Oct 21, 2008 · 04:29 UTC#1
i saw the post that how to bypass and testmod..
then i tried everything..nothing works
first fommated sdcard(kingston 4gb..and sandisk ultra2 2gb)
2ed and copied two polder for doing testmod
3ird unit turn off and put sd card inside
4th and turn on
then i can see system startup in progress. that's it nothing happen..
it drives me crazy...plz somebody help me..my unit is f500bt
Posted Oct 21, 2008 · 05:04 UTC#2
tell me about it. its not working for me either. im looking on other threds but no luck. this is not for the savy
Posted Oct 21, 2008 · 05:25 UTC#3
Just click the X in the upper right corner to close out the window left after booting into test mode. Then you will have access to the system. Use the provided stylus that came with the unit to click on the various files.
Posted Oct 21, 2008 · 05:40 UTC#4
ok dude got it! you need to extract the files onto you sd card: "Testmode" and "MiTACAP". put these files on your sd card. dont do anything else with the files. before turning on your ignition put in the sd card. it will show the splash screen for a minuet or so and then a white screen will pop up showing "copying". after thats done use your stylus and tap the "x" in the top right corner. and thats it. youve booted into windowsCE
Testmode.zip
Posted Oct 21, 2008 · 06:17 UTC#5
what a nice of you guys..thanks a lot
Posted Oct 21, 2008 · 13:39 UTC#6
...hasn't that step been mentioned numerous times? to extract the 2 folders onto the root of the SD?
Posted Oct 21, 2008 · 15:16 UTC#7
yup. all the forums were saying put the files on the card. its not specified to the root it just needs to be clearer to us noobs. for another example, i have no idea how to get into code to hack different things. it doesnt say if its done on pc or ce. or if you need a program to see code in these files. its makes me go insane :shock:
Posted Oct 21, 2008 · 16:32 UTC#8
The codes are rewritten on your home computer and should never be done inside the unit, given that it's even possible.
