drober30 said:
I did not receive any instructions. Just the white envelope with the disclamer on it.
That's how I ship them
drober30 said:
I followed the directions on your website
http://www.sminntech.com/z1fcinstall.html
Your circuit has a white paint spot on it if that means anything.
The instructions would have been in the email I sent to you when I shipped the circuit. The white dot is a new software version so I know who has what, there is a secondary installation procedure which you could use if you have trouble (usually due to diesel vehicles, or auto starters, or can bus adapters or whatever). 99.5% of people didn't have a problem with the "old" software, but I had to make a couple custom versions for some people and these "white dot" circuits have both programs in them hoping to get rid of any custom software.
drober30 said:
I thought it was pretty straight forward.
I removed the red wires of the TR7's and added your RED wires in it's place.
I removed the black wires from the TR7's and added your BlACK wires in it's place.
I removed the blue wires from TR7 and added ORANGE in it's place. (Removed diod too)
I removed the green wire from the 5 second TR7 from the amp turn on and added nothing in its place.
I removed the green wire from the 20 second TR7 and added the WHITE wire in it's place.
I don't know how to install a TR7 so I can't go by the color codes on the TR7. But it sounds ok, I would go more by what the TR7 was connected to as opposed to what color the wire was on the TR7. But it sounds ok.
drober30 said:
I did nothing with the light green wire comming from the Z1. This is attached to some other wires, I think ground but I have to look closer.
The light green wire is the parking brake wire, it should not have been connected to anything, even with the TR7's. It should not be grounded. If it is, the Z1 will not respond reliably to TR7's or my circuit. If it was grounded the unit will need to be reset.
