N2 - no music sound, but i do get menu sound
By puckslinger · Oct 23, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,192 views
Posted Oct 23, 2008 · 11:01 UTC#1
Hey guys,
Trying to track my issue down couldn't find my issue on the search
Everything seems to work fine, except for music noise. Both my Ipod and radio will both load and show that its working properly but there is no sound of music, when i go to another song or station i do hear the system beep in the speakers. Any ideas why i would lose my music sound and not all sound? and how I go about getting it back??
Thanks,
Puck
Posted Oct 23, 2008 · 12:54 UTC#2
Hey guys,
Thanks,
Puck
Off hand, the volume could be turned down, the sound not directed to the speakers in the audio section, you may need to reset the system....
regards
~Marc
Posted Oct 23, 2008 · 17:53 UTC#3
when i turn the volume dial the numbers do go up and down, but no change for the music. I also reset the unit, detached the extra stuff i didnt need and reinstalled from scratch checking the connections and such along the way. with no luck
Posted Jan 28, 2009 · 15:05 UTC#4
I have the exact problem. I have no sound from any music sources. I can hear the tones when selecting things and the voice guidance still works but no music!! arggghh! Please help! it sucks to drive with no tunes!
Posted Mar 01, 2009 · 08:02 UTC#5
Whoa, that's a strange one.... Ball lightning, maybe?
Posted Mar 01, 2009 · 11:17 UTC#6
Do your vehicles have an external or factory amplifier?
Posted Mar 30, 2009 · 20:22 UTC#7
i have both. sub to external and fronts to stock head unit . odd thing i took my unit out cause it was useless, and recently put it back in and it worked fine. then again after about a week it did the same thing again. starts with 1 sound level. regardless of the dial number it doesn't change the sound level and when you go to 00 it turns off and 01 goes back to what ever level it was when it went nuts. then it doesn't produce any music sound.
