EQ - Post up yours
By 1sicka4 · Oct 24, 2008in General💬 2 posts👁️ 722 views
Posted Oct 24, 2008 · 20:20 UTC#1
I usually listen to hip hop and im having trouble setting up my EQ to sound perfect.
Can you guys post up yours?
Posted Oct 24, 2008 · 21:59 UTC#2
If you don't mind spending a few extra bucks, having an external EQ can help you set up your music a lot easyer and with better results (if you have an amp, if you don't then this won't work). I have the EQ on my F-series flat and lowdness on Middle. I just change EQ frequencies on the external EQ, sounds awsome. Also some external EQ's like mine have a higher pre-out voltage than the unit's which makes it possible to set the gains on the amp higher without getting any of that horrible hisssssssss noise. The voltage that my unit gives out is 2V and the EQ gives out 7V. The difference is unbelievable. This is the one I use, I got it for $65 on sonicelectronix.com
http://www.clarion.com/us/en/products/2 ... 13691.html
