I just installed a F900BT is a 2008 Audi A4, and i get a severe huming/buzzing sound whenever the headlights are on. My car has the Bose system and i usedthis harnessto connect it to the Pioneer. From searching I have tried the following with no luck:
-Tried 2 new grounds for the HU, on different sides of the dash (no difference)
-Tried grounding the chasis of the HU (no difference)
-Tried grounding the RCA's (noise got even louder)
-Disconnected the illumination wire (no difference)
If i disconnect 1-3 of the RCA's from the harness, the noise more than doubles in volume. If i disconnect all 4 the noise stops. I'm really at a loss here and would appreciate any advice. The only other thing i can think to try is some RCA ground loop isolators like these but I'm not sure which kind i should get. I dont mind spending a little more if it will give me a cleaner signal.
P.S.
I know this is not F-series specific but the vehicle specific board is pretty dead.
