I'm having a problem with the installation of my rear view camera, I'm not sure electrically what is happening, but operationally when the car is shifted into reverse the camera will come on and there will be warning text that says the picture may be reversed, then the image on the z1 will automatically switch to whichever image was on the screen prior to the car going in reverse. After a couple of seconds the image will then switch back to the camera. This switching back and forth of the images will continue until the car is shifted out of reverse. In addition, when I choose the split screen map mode that is supposed to show the camera image in one window and the map in the other, the camera image is non-existant. The screen just goes blank in that window.
Thank you for any help that you can provide. I tried searching this forum, but couldn't any info about the rear view picture switching automatically back and forth from the camera image to a non-camera image.
Ducatiboy,
If you see this, thank you for sending your light flicker circuit. I received it a couple of weeks ago and had it installed last weekend. The circuit worked great and makes the z1 a much more user freindly unit. :D
Posted Sep 13, 2006 · 00:48 UTC#1
