Avic Z3 whoo's
By barryg · Oct 26, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,171 views
Posted Oct 26, 2008 · 06:35 UTC#1
I recently bought the new Avic Z3 and it will not learn the route I travel no matter what I do. Ieven call Pioneer and they told me to reset the unit and disconnect the speed pulse wire and nothing happened The Avic Z1 I gave to my brother was perfect.
has anyone experience this problem and can you tell me what to do.
thanks barryg
Posted Oct 26, 2008 · 21:50 UTC#2
If I am correct, make sure that the auto learning function is enabled through the menu...
Posted Oct 27, 2008 · 01:39 UTC#3
what exactly does the learning feature do? does it just remember that you take a different route then it thinks you should take, and then route you that way? why use navi if its a route you take all the time? im confused...
Posted Oct 27, 2008 · 02:16 UTC#4
This feature works great for me. I have multiple ways I can take but I usually take a particular road. So whenever I input an address for navi guidance that goes through that area, it chooses that route in particular.
You should check to see if that option is turned ON in your settings menu.
Posted Oct 28, 2008 · 02:25 UTC#5
Hi Avic Nation
All of the above you suggested was already done even before I call Pioneer and they asked that Question and told me to reset the the unit.
Posted Oct 28, 2008 · 02:59 UTC#6
where in the menu is this?
