Bought a JDM Pajero and has this navigation installed.
Anyone have G-90? Anyone got one working in North America and is there a compatible NA map disc out there?
If not I will try to install CNDV-80MT and post the results.
If that doesn't work, I bet you could probably make a hybrid disc using the newer map data with your original application files if it uses the standard Kiwi (.kwi files) like the NA discs do.
Do you think they will have something comparable in US as far as 7inch 3d mapping like this?
