WM5 beaming multiple contacts
By mtxpert · Sep 13, 2006in Problems/Troubleshooting💬 10 posts👁️ 2,000 views
Posted Sep 13, 2006 · 05:57 UTC#1
Looked on my i730 phone forum and found that Pocketinformant will allow you to choose multiple contacts by using the shift/tap (I chose my whole address book) and beam them.
I put all 130 contacts in my radio in about 45 seconds.
Pocketinformant is a free download and trial.
Just FYI.
Mike
Posted Sep 13, 2006 · 14:21 UTC#2
cool beans.
Posted Sep 13, 2006 · 19:05 UTC#3
Nice tip. Thx.
Posted Sep 14, 2006 · 03:19 UTC#4
thats both awesome and sad. I also have teh i730. i loaded all my contacts 1x1. took like an hour. oh well if i ever need to do it again im set, thanks for the tip
Posted Jul 12, 2007 · 09:59 UTC#5
Downloaded and installed Pocketinformant.
Few questions:
Is there a button in the menu "select all"?
How do i choose to beam by bluetooth? The only option i see is beam by IR.
So anyone can make me a step by step guide how to beam all my contacts using bluetooth to a Avic D3.
Thanks guys :wink:
Posted Jul 14, 2007 · 14:49 UTC#6
Solved:
With pocketinformant i transfered all my 280 contacts in 10 minutes to the D3.
Posted Jul 23, 2007 · 15:05 UTC#7
The only problem with pocketinformant is that they haven't put a buton "select all"in the program. You have to drag all your contacts and then select "send as IR"
If anyone knows an program whit a buton "select all" please inform me. I cant work easely with pocketinformant because i have more than 300 contacts.
Posted Jul 23, 2007 · 16:37 UTC#8
I don't know what program is in my sprint ppc 6700, but I was able to select all and transfer all of my contacts to my Z1 and Z2. I loaded a custom rom that I got from PPCGEEKS which erased all the stock sprint software and loaded my phone with a package of much more useful stuff including much better bluetooth software and every program I need.
Posted Aug 13, 2007 · 22:32 UTC#9
My PPC has a custom on-screen keyboard called the mUn Keyboard Skin, downloaded from www.xda-developers.com (not sure where), in which I can hit CTRL and then A (even though my actual keyboard has no CTRL and the standard WM5 has no keyboard either).
Only problem I seem to have is that it will not beam more than 40 contacts at the same time... with 400+ contacts I still have a long way to go as I cannot use the CTRL-A trick.
Anyone else experience the same problem with max. 40 contacts?
Regards,
Nika.
Posted Aug 13, 2007 · 22:52 UTC#10
No problem for me with maximum contacts, I don't know what add on or program included in my rom does the work.... but I am able to go to my contacts screen and in the menu I found "Select all" and then I found "Beam selected contacts" probably about 200 or so contacts transfered no prob.
