POWER Antena issue
By sicqx4 · Oct 27, 2008in General💬 5 posts👁️ 995 views
Posted Oct 27, 2008 · 01:38 UTC#1
Installed the F90, and power antena always goes on upon start. the ANT feature does not shut it off, any suggestions on why this is happening?
Posted Oct 27, 2008 · 02:07 UTC#2
Which blue wire did you hook it up to in the decks harnesses?
Posted Oct 27, 2008 · 03:50 UTC#3
I ahd this installed, so im not entirely sure.
Thought maybe someone has had the same issue? so I could go back and tell them to fix?
Posted Oct 27, 2008 · 16:15 UTC#4
I'm betting they connected the antenna to the amp enable wire instead of the antenna wire. The antenna should only go up when you are utilizing a source that requires it.
Wait...what if you have MSN enabled? That requires FM, right? Would that make it turn on with the unit power?
Posted Oct 27, 2008 · 16:39 UTC#5
There is an option in settings to have it have the antenna up whenever the unit is powered on or only when a source is using it. I don't know if you tried that yet.
