AVH4000 DVD
By NUNES · Oct 28, 2008in Pioneer AVH Series💬 4 posts👁️ 2,617 views
Posted Oct 28, 2008 · 14:54 UTC#1
Hello. I just have a quick question about the p4000 dvd player.
Did anyone have any problems with the radio, where the stations dont come in.
I have it installed on a 07 wrx, and the radio stations come in really bad. i hear static and it breaks on and off.
Does anyone have any ideas how can i fix that?
thanks in advance
Posted Nov 01, 2008 · 17:42 UTC#2
didn't have any problems with mine. You probably have a powered tuner in your car thats factory. Did you hook up the the power ant. wire on the harness? should be a blue wire on the harness that connects to your factory plug. The 4000 won't have that wire just the blue white/system remote wire. just hook it to that and you should be fine.
Posted Nov 11, 2008 · 20:40 UTC#3
did you tint the rear window with metallic tint? the antenna is built in to the rear window so if you use metallic tint it will interfere with the radio.
Posted May 28, 2009 · 14:38 UTC#4
Double check to see if your antenna is connected into the head unit. It may require an antenna adapter to go from OEM output to Pioneer input
