I currently have an avic-d3 and just got a f900bt. Is the harness and gps antenna connector the same? Plug n play swap out.
Sorry if this has been asked many time but apparently my search skills suck at the moment.
Jason
Jason
The harness is the same. The antenna has a different plug on the end but can be easily modified to work. The bypass hole is different on the RCA harness (if you choose to bypass)
So if I just swap the end of the plug (the plastic piece) it will plug right in?
Ya
Ya
Figured that after I took it apart... thanks.... swapped that... moved the mute wire... all done.
Jason
Thanks again...
