Issue with AM Radio
By CG84 · Oct 29, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,151 views
Posted Oct 29, 2008 · 22:06 UTC#1
I had my AVIC-F700BT installed this weekend by a friend (he's installed these and several others before). Everything works great except my AM radio! I only get one channel that I can barely hear and it happens to be a channel I never listen to. Just wondering if there was a missed step when installing the HU. Going to go check out the store I got it from and see if the one on display can pick up the channels I listen to (790, 980 and 1070 in SoCal).
Anyone have an idea what could be going on?
Posted Oct 30, 2008 · 02:35 UTC#2
Does your car have a powered antenna built-in? He may have neglected to connect the wire from the deck that triggers the antenna to power on
Posted Oct 30, 2008 · 02:42 UTC#3
I'm not sure if Scions have a built-in powered antenna (never heard of it actually), if we do that might be it. However, I do have an aftermarket fin over the base of my antenna (guess this means no built-in antenna?) but it worked fine with my stock HU. Have yet to get over to the store I bought it from to test their AM radio. :?
Posted Oct 30, 2008 · 07:30 UTC#4
Did you connect the blue antenna wire on the wire harness to the pioneer blue power antenna wire? I forgot to do that with my Scion and I wasn't able to get AM either but after I connected those wires everything works. But I still feel the stock scion radio gets better reception.
Posted Oct 30, 2008 · 07:48 UTC#5
Not sure since I just watched my friend install it. I'll take it out tomorrow and take a gander. Hopefully this is the problem and not something else.
Posted Oct 30, 2008 · 10:46 UTC#6
THis sounds like it. Subaru WRX's are the same way, and the 04 STI's that didn't come with a factory stereo also need to have the antenna plugged in from the rear shield to the harness in the trunk.
Posted Oct 31, 2008 · 20:30 UTC#7
Ok so the blue power antenna wires WAS the issue. That's really silly to need to put those wires together in order to get a better AM radio reception and possibly FM radio reception. So happy now :)
Thanks for the suggestions about the blue wires guys!
Posted Nov 01, 2008 · 00:19 UTC#8
No Prob. Glad you got that fixed..
