Greetings all,
I built this unit from surplus parts to solve the problem of interrupting the booting sequence each time I start my diesel Ford Excursion. When you first turn the key in a diesel to heat the glow plugs, power is switched on to the audio/nav unit and it starts to boot, then in a few seconds you turn the key to start and it cuts power to the audio/nav interrupting the boot and it has to start over again when the key is released.
I don't have any hard numbers but several installers that have had problems with pioneer audio/nav units recall many being in diesel vehicles so my theory was, "damage due to interrupted boot sequence". At first I put in a toggle switch to manually control the power to the Pioneer but that got old real quick.
This unit takes the place of the toggle switch I was using. I adjusted the delay time to 8 seconds and haven't had a "double boot" yet. You can adjust it to your vehicles needs. I found the relay in an electronics surplus store for $7.00. The relay's coil is wired to the existing +12V switched power source and ground, then use the N/O (normally open) contacts to switch the power.
Hope it helps extend the life of your unit as I "believe" it is for me.....
Sam
