Finally Solved it.
Here's the solution:
LANGUAGE FATAL ERROR: If you get a fatal error message and a reboot in entering the language settings, doing a "factory setting recall" on settings/navi settings will enable you to go into language settings with no problem
CAN'T CHANGE VOICE LANGUAGE: If your system freezes when trying to change the voice, boot into testmode go to Myflasdisk/user/userdata/setup and delete all 5 files there.
When you reboot, the system will ask you your language preferences as if you installed the machine for the first time. Choose the ones you like and the system will start up as normal. You' should not have the freeze problem again. You may see in igo that it shows another region or country when done this move. Just go into destination/adresses and change the country and city to your preference and you have a brand spanking new and full working system.
