"Please insert appropriate disk" solutions??!!
By chargerRT · Oct 31, 2008in Problems/Troubleshooting💬 9 posts👁️ 3,421 views
Posted Oct 31, 2008 · 06:22 UTC#1
So do we have to get the upgraded/newer East and West navi disk so that the "Please insert appropriate disk" would go away???
Posted Nov 01, 2008 · 17:18 UTC#2
I can't imagine you would have to upgrade to get the message to go away. It more likely the motor in the drive or something is failing.
Posted Nov 04, 2008 · 02:22 UTC#3
I have this same problem. Contacted Pioneer Service and they said I need to send it in for repair. $200 for the repairs as the unit is out of warranty. I'm considering changing to a Z-2 or 3
Posted Nov 05, 2008 · 16:29 UTC#4
Whenever I switch discs to a newer version, it will display that message for a little while - 10 seconds maybe. Then it will reboot and upgrade. If I've upgraded and I put in an older disc, it will have that message. Make sure you're using a disc as new or newer than you've previously used in the unit.
Posted Nov 05, 2008 · 16:46 UTC#5
Mine upgraded OK used it for half a day--then it died.
Before the upgrade the drive was making a loud clicking noise and it seemed to get worse.
Finally after upgrading and using the vehicle for a while it just displayed that message. Now with the new disk it displays that error message.
Posted Nov 05, 2008 · 16:49 UTC#6
Wow... I'm no expert on this kind of thing but it sounds like maybe the disc you burned was bad and it somehow caused damage to the unit. I'd try going back to whatever you had before that and pressing the reset button to see if you can get it to downgrade or something. I can't really say more than that what might be happening.
Posted Nov 05, 2008 · 17:04 UTC#7
I tend to agree. But I have not been able to downgrade. I see others have similar experiences over at this thread:
http://www.avic411.com/forum/viewtopic.php?t=18827
So I'm shopping for a z2 or z3 just not sure I'll install it myself.
I was thinking also about the F series but the smaller screen is
Posted Nov 16, 2008 · 04:39 UTC#8
I am having serious problems with these updated discs as well. Worked great at first. Now not so much at all. It was a mistake to even bother with them. I will not be recommending them to anyone.
On a side note, I was trying to perform the downgrade.... and after I release the eject button (after the release reset button alert is displayed), entering the code does nothing for me. I type it in and nothing. Hints?
Posted Nov 16, 2008 · 06:58 UTC#9
I'm in the same boat. After I upgraded my D2, everything was great, but after a week or so it stopped showing a map at any resolution greater than .5 miles, which makes it basically useless. I'd be happy to downgrade, but I don't know the procedure - can anyone help out?
