distorted pic on backup camera
By grcplaya · Sep 14, 2006in General💬 4 posts👁️ 2,750 views
Posted Sep 14, 2006 · 03:53 UTC#1
anybody got a solutions for this, it works and everything but the pic is very distorted. I used a kenwood camera cuz of the way it mounts.
need help.
grcplaya
Posted Sep 14, 2006 · 12:22 UTC#2
I had an intermittent distortion problem with my pioneer camera. It turned out to be a loose connector connection at the Z1 unit. When I was checking the connections, I heard a click sound around the connection which meant that it was not secured. Now the image is perfect all the time. You can do some troubleshooting by hooking up a camcorder to the video input to the Z1 and see if the image is distorted. If it is distorted, then the Z1 has a problem. You can test the camera by hooking it up to the AUX input of the Z1 and see if it is distorted.
Posted Sep 14, 2006 · 13:36 UTC#3
We have "spot monitors" to do just that. You can actually use your camcorder to do same. If not, use a portable tv. Just make sure the power to the cam is good.
Posted Sep 14, 2006 · 21:12 UTC#4
well I went an took out the Z1 to see if all the connections were secure buu then I noticed the neg. connector for the camera Rca input was not pushed in all the way on the harness so I took care off that and presto we have a better pic NOw :D
remember check the All connections before you put all back in!! make sure they are in place
thanks guys
grcplaya
