Hey all,
I've been struggling with this thing all night already and need to get a bit of rest before getting to work in a couple of hours. Ugh.
Three issues I'm unable to overcome:
- I'm getting this loud hissing sound from my speakers. While the music/radio and such are all at acceptable volume levels, I still get a very audible hiss that I can drown out with the music.
- The factory sub (2008 Honda Accord sedan) in the rear is not functional at all with this deck. I have a feeling I need to find the remote wire for the factory amp under the passenger dash, but I'm not sure what specific wires I can split.
- I might have a bad VSS... I read that it's "a blue wire" on the main factory harness, which I split. No problems, but man, anything I did wrong up until this point can be causing the hissing.
I hope you guys can all help, I have long drives to deal with, and this is really not turning out as well as I was hoping. ![]()
Edit:
Some additional details for you.
- Soldered all connections, taped over. Could be a crappy ground, I wiggled it around while I heard the hissing, no change. I wiggled all the cables around. : /
- I re-pinned the mute cable so I can bypass the parking brake lock, and grounded it (same ground as below).
- I did not connect the ground that was on the Metra wiring harness to the deck, I just grounded the deck right to the chassis. Not sure if this matters, but I wanted to mention.
